E vs. Emissions
  • Thread starter Thread starter E_SolSi
  • Replies Replies 51
  • Views Views 13K
E_SolSi
Member of the 20 nut club
Moderator
VIP
2 years ago i put my sol back on the road
to register it i needed to go through emissions
in my state even if you fail you can still register the car, and you were given 30 days to retest it free of charge (now 60 days)
but you can still keep your registration, so you are good on a failed car for 2 years... although not completely legit
if you failed again you would be unable to re-register the car until you passed
anyway back to the story... i built this car about 8 years ago when my state canceled its emissions program for a few years... my JDM ITR swapped sol was running pig ass rich on a modified Skunk2 map (kenji from H-T) touched up with a VAFC... i took the car off the road for a few years while i cleared up some issues... 2 years ago i decided to put it back on the road again
and when i tested it two years ago i failed MISERABLY
how miserably you ask???
here are my original numbers from 2 years ago:
(normal 10% alcohol pump fuel)
HC ppm -- limit: 188 -- actual: 227 = FAIL
CO% -- limit: 1.00 -- actual: 6.22 = FAIL
NOx -- limit: 2188 -- actual: 377 = PASS
final result = FAIL
didnt much care about the fail as i was registered and wouldnt really need to worry about it again for 2 years...
but i did have B find me a new map to run... found a map that is supposed to be a pretty close simulation of a stock ITR map... burned that to a chip and zeroed out the settings on the VAFC and everything seemed a hell of a lot better... car still seemed to be running a bit rich but my mpg doubled so it definitely seemed leaner than it was
fast forward to this year and its time to re-register which means i need to pass emissions now... i go get tested with my much cleaner map running the car... and get these results:
HC ppm -- limit: 188 -- actual: 215 = FAIL
CO% -- limit: 1.00 -- actual: 6.38 = FAIL
NOx -- limit: 2188 -- actual: 538 = PASS
final result = FAIL
WTF!?!? i failed just as bad as i did before even with the leaner fucking map
so i start looking at my options...
i can lean it out on the VAFC and see if i can get it clean enough to go through (played around with it a little)... i can fuck with the ignition timing to see if i can get a more complete burn (not real confident playing with that)... i can try to replace my high flow cat with a stock one (dont really want to)... i can try to put a stock P28 on it and run a D16 map (couldnt find my old P28 i think it got tossed)... i can spend a bunch of money on getting re-tuned and hope that they can get me on a map that is clean enough to get me through emissions
or...
ive heard of people running alcohol in their gas to pass emissions... but dont know anyone who has and ive heard a lot of horror stories... i dont want to destroy a $5000 engine trying to pass emissions
i start researching my options...
i find a bunch of info on running denatured alcohol as a way to sneak past emissions... most of it garbage... some of it a little helpful... some of it very helpful
i start running some numbers and decide im going to run 2 qts maybe 3 in the about 3 gallons of gas in my tank
so i go to Home Depot and pick up 2 qts of Denatured Alcohol (zeroed out the VAFC again)
the morning i am going to go for my re-retest, i dump the 2 qts in the tank and go for a 20 minute ride to warm the car up and get the alcohol fully mixed in...
i go to the test station... and i wait for my results:
(blended fuel about 23% alcohol)
HC ppm -- limit: 188 -- actual: 192 = FAIL
CO% -- limit: 1.00 -- actual: 4.31 = FAIL
NOx -- limit: 2188 -- actual: 317 = PASS
final result = FAIL
fuck :(... but it showed improvement :)
looking at my numbers i figure another 4 qts should clean me up enough to pass... but shit thats a lot of alcohol to run in my car... so im a bit nervous
i go buy a 1 gallon can of denatured alcohol, and i head back home to do a little more research...
trying to find more info on how much alcohol i can safely run in a non flex fuel vehicle i finally decide to try searching for: "what if i put e85 in my car"... which brings me here: E85 Conversion Kits Change2E85.com
1-7 are exactly the kind of information i needed
feeling pretty comfortable now... i dump the gallon in to the tank
i go and drive around again getting everything mixed in and warmed up and go to get re-re-retested:
(blended fuel about 50% alcohol)
HC ppm -- limit: 188 -- actual: 106 = PASS
CO% -- limit: 1.00 -- actual: 0.93 = PASS
NOx -- limit: 2188 -- actual: 1650 = PASS
final result = PASS
:D :D :D :D :D
fuck yeah i made it through!!!!
drove the tank down to just about empty then went to the gas station, topped off my car with regular gas, and excited as hell i went to get my car re-registered
i called and told neonmike about my success, because he has been having a whore of a time getting his turboed neon through emissions... and i thought this just might do the trick
i also continued looking for information on running cars on alcohol... i stumbled across this article... and found a lot of useful information in there
Mother Earth Alcohol Fuel: Alcohol as an Engine Fuel
this part i found especially interesting
[FONT=Times New Roman,Georgia,Times]EXHAUST EMISSIONS[/FONT]
[FONT=Times New Roman,Georgia,Times]When gasoline is burned in an engine, it produces carbon monoxide and other poisonous fumes ... mostly because of the fact that the fuel never combusts completely, and also because it's subjected to extreme temperatures and pressures. In addition, as we mentioned before, gasoline is a complex mixture of many substances ... and some of those substances are lead, sulfur, and other noxious materials. These, too, add to the contaminative effects of the engine's exhaust fumes.
Alcohol, on the other hand, burns much cleaner. Even though it, too, never combusts completely, the volume of noxious fumes is drastically reduced in an alcohol-burning engine ... because alcohol contains oxygen in its structure (which means more thorough combustion) but doesn't contain all the other pollutants necessary as additives in gasoline.
For comparison purposes, MOTHER's researchers ran tests on a 1978 Chevrolet taxicab ... which, operating in New York City, was subject to some of the most stringent pollution controls in the nation. (In order for cabs to be licensed, they must undergo - and pass - four scheduled EPA tests a year for carbon monoxide and hydrocarbons emissions.) Naturally, the taxi that MOTHER's crew tested was a lot less polluting than the average American automobile, but even in perfect tune it just "squeaked by" the tests using gasoline ... registering nearly a 1-1/2% CO and a 200 parts per million HC exhaust content (both just under the legal limit).
With alcohol fuel, however, the test results improved enormously. Even with all pollution controls removed from the engine (except for the PCV valve), the cab registered a mere 0.08% CO and only 25 PPM of HC ... the equivalent of 95% less CO and 87.5% less HC, or a total of about 92% cleaner! [/FONT]
i guess i should say, Denatured Alcohol does not fix any of the actual reasons your car is failing emissions... and whether it will help you depends on why you are failing... and you should still look into getting your car running properly and clean to protect the environment, and for the children dammit!!!
but if you are failing because you are running rich, i can comfortably say :yes: Denatured Alcohol can safely be used to get your car though the sniffer test for emissions
how much you need to use depends on a few things:
how badly you are failing... the worse your numbers are the more alcohol you will need to run
how rich your car is running, and how high a percentage of alcohol are you going to try to run... alcohol needs to run a lot richer than gasoline in order to run well... running too high an alcohol mix can cause a lean misfire if you are not running enough fuel
whether or not your car is running ok or not (ie: if your car is just a piece of shit and barely runs i dont think alcohol will fix you)
all of the pages i found with people talking about tossing 1/2 a qt or a full qt into 10 gallons and passing, they must not have been failing by much at all... they probably could have passed by just driving around and heating up their cat (if they would have failed at all)
the 1-2 qts to 1-3 gallons will probably get most normal decent running unmodified cars through
if you are running pig ass rich though, you are going to need to run a LOT of alcohol...
my recommendation... run your car almost empty and pour in a gallon of denatured alcohol, then drive that off till its almost empty and pour in another gallon...
that should have you on just about straight alcohol... drive around for about 15 minutes and go to the testing station... if you dont pass with that, im not sure you can be helped (if your state has limits for how low your numbers can be you cant run straight alcohol... it burns wayyyy to clean... you will have to find your own mix ratios)
as always:
****TRY AT YOUR OWN RISK****
neither hondaswap, its owners, any of its staff or myself are responsible for your actions or the consequences of your actions...
if you are going to dump industrial solvents into your fuel tank you are doing so on your own
First off let me say this trick works well but if you blow your car up(which i would have to say from my extremes is impossible) its not my fault. Now for a little back story, I built my car when emissions was not in effect so i have no idea what the car really would blow on a sniffer stock. Shortly around 2004 emissions came back but what they don't tell you is if your obd2 and you fail it your car goes to the sniffer and won't be let back to obd test until it passes the sniffer, well surprise surprise mine failed but it was my own fault i had a bad downstream o2.
Test 1
HC Limit 150 Actual 202 Fail
CO Limit .80 Actual .79 Pass
Nox Limit 1750 Actual 1653 Pass
Test Fail
Now it was a fail but pretty damn close with no cat on the car. Car also had stock 2 1/4 exhaust still on it. Now flash forward to this year i finally have the car back together and want to get it registered. I go with the same setup i had before but it now has a 3 inch exhaust and a brand new cat on it, no its not even a high flow. Now mind you all tests have been done with the boost pipe disconnected and it running on the stock ecu not my standalone.
Test 2
HC Limit- 150 Actual 242 Fail
CO Limit- .80 Actual- 3.64 Fail
Nox Limit- 1750 Actual 334 Pass
Test Fail
Wtf i put it back to stock almost and it has a cat how did it get worse? I lost my test 3 results but it was the same as test 2 and I lowered my fuel pressure alot so that's 3 tests down failed. next one is with the addition of that CRC Guaranteed to pass garbage
Test 4
HC Limit- 150 Actual- 281 Fail
CO Limit- .80 Actual- 4.01 Fail
Nox Limit- 1750 Actual- 445 Pass
Test Fail
Now here comes the fun part, E tells me about the alcohol and i say sure i have tried everything else why not. I added 2 gallons to roughly 3 gallons of gas and take it back through after a nice long warm up ride.
Test 5
HC Limit- 150 Actual- 210 Fail
CO Limit- .80 Actual- 2.93 Fail
Nox Limit- 1750 Actual- 782 Pass
Test Fail
Okay now i am heading in the right direction, drive it down to an 1/8 of a tank and add another gallon of alcohol.
Test 6
HC Limit- 150 Actual- 75 Pass
CO Limit- .80 Actual- 1.29 Fail
Nox Limit- 1750 Actual- 687 Pass
Test Fail
Okay now i am on to something here, call up E and we decide drive it empty add 1 more gallon of Alcohol. I take it down some twisties and sputter to the end of E's driveway, add 1 gallon and off the two of us go not expecting much more out of it.
Test 7
HC Limit- 150 Actual- 23 Pass
CO Limit- .80 Actual- 0.01 Pass
Nox Limit- 1750 Actual- 870 Pass
Test Pass
So in conclusion my car was running on 100 percent alcohol and it blew cleaner than any hybrid out there. If any of you need to pass emissions and can't i highly recomend looking into running alcohol through your car it will pass anything as long as it can start on its own. Oh and yes that is not a typo it blew a 0.01
For us in Cali, keep in mind that we can also fail for o2. So if the o2 and CO percentages are too far from each other, we'll fail for o2 dilution. The same reason you disable the air pump on air pump equipt (sp?) vehicles while running a smog test. I figure the release of the extra o2 molecules in the alcohol may have this affect.
Good info though, E :)
thank you for pointing that out :thumbsup:
they dont test for that here... so it was a non issue for mike and myself
we just have the visual cat check, a gas cap check, and a 3 gas sniffer test on the rollers for OBD-0 or OBD-1 cars, or a plug in computer check for OBD-2
Yeah, we fail for damn near everything. If the smog guy doesn't like your air freshener, you'll fail...
I did this same thing to pass my civic through german emissions. They used a 5-gas sniffer though. I'll see if I can dig up the documents (not very likely since I just sold it.)
if you remember the ratios and can get the readings that would be awesome
i would like to build up a good reference base in this thread for anyone else who is trying to research this... theres way too much worthless crap out there
speaking of which... anyone who tries this, please post up your ratios and results
please use a similar format to the above posts
thanks :thumbsup:
Let me see if I can dig up my old course book from my Drivability and Emissions class. It has Rule of Thumb specs on what you'd want to see on the sniffer/analyzer.
...Wait.... You can... fail. For emitting, diatomic oxygen... the substance we breathe. The substance for our entire respiration, you can fail for? I'm 96% sure that's 100% retarded.
Lol yup. It's not so much considered too much oxygen though. It's because too much o2 content in the exhaust stream will cover a high HC and CO problem. High o2 can indicate a lean mixture but you'll usually find or confirm the lean mixture with a high NOx level.
Jesus christ you need to get your shit properly tuned E. Do you have a WBO2 sensor? My car runs anywhere from 12-13.5:1 afr at WOT and like 13-15:1 idle and light throttle. 99% of the time it's running without a cat. But last month I was due for emissions on it. I had SMSP (guy who made my header) fab me up a cat that would bolt on since I needed one for emissions and I didn't feel like taking it somewhere to have some hillbilly "custom" fab one up. Anyway with my cat on I went to get emissions tested and it blew something stupid low like 14-HC and .04 CO2, which was actually a lot lower than the first time getting tested two months ago when I failed for the gas cap. But I was still well below the thresholds on everything. That was on my 215whp 93 pump gas NA B18C engine that's in the CRX.
Maybe it depends on the testing method as well. Did they put the car on the rollers? In MD they used to put the car on the rollers and run the car at varying speeds and rpms. But now MD has eliminated the rollers and just has you shut the engine down, then start it up, hold revs a bit fir a few mins (I held it at 2000 rpm :) but my exhaust is loud so maybe he thought it was higher lol), and then you're done. Plus the gas cap pressure test and visual cat check
yeah i know i need to get it tuned properly... but i didnt really want to spend the money on getting that done right now... i just needed to get the car registered... i will take care of the tuning over the summer and get a map made specifically for my car
I just want to point out that a lot of the ethanol tree hugger bull shit in E's article is fucking propaganda. Ethanol's safer for the environment blah blah blah. Helps farmers and food supplies...uh huh
Wanna know why there are no CRXs that make 50MPG like they did in the 90s? Yeah. The whole hybrid craze is falling on the back of ethanol and it just pisses me off.
Ever notice how much the price of an ear of corn has gone up at the grocery store in the last 5 years? Wanna take a guess at why? Might be there are more farmers growing corn for the ethanol subsudy, so to make up for not selling it to a refinery you get fucked. You also get fucked due to the other shit said farmers could grow, but dont, since it's not as profitable. Less competition = higher prices. Fucking Iowa. This whole E85 bullshit would have gone away if Iowa wasnt the first state for presidential primaries. Fucking pandering by both parties in that state is what caused the 10% in all gas. Not to reduce emissions (if we wanted to do that, we would have ratified kyoto).
[/rant]
E's experience at the sniffer though is 100% valid though, so :thumbsup: for that.
I can't find my actual emissions course book right now but I found some from my diagnostics course book. It's not much but I suppose it's better than nothing right now...
CO2 - Indicator of overall combustion efficiency. Higher reading is better. Should be at least 10%. Ideal - 13% or higher.
O2 - Level of o2 in the exhaust after normal combustion should be very low. 1-2%.
Peak NOx level is reached on slightly lean side of ideal A/F Ratio. Typical NOx production is 1700 - 2500 PPM. Vehicles with EGR's should be under 1000 PPM.
final result = FAIL
final result = FAIL
or...
final result = FAIL
final result = PASS
:D :D :D :D :D
as always:
Just sent post this to the New Britain DMV
