Finally back in the garage....
  • Thread starter Thread starter Airjockie
  • Replies Replies 427
  • Views Views 77K
I think he's talking about the lateral offset from lip of rim to edge of tread, which looks to be a few inches.
I'm not seeing a difference anywhere near that large.
yeah the bulge is fine... i was always told to keep the edge of tread even with the edge of the rim.
Depends on the application. You get better grip and breakaway characteristics while cornering if you stretch the tire a bit over a wider wheel- just not exceeding the tire manufacturer's recommmendation though.
After looking again at this pic
It doesn't look bad, the other pics make it look worse.
just need to raise the car up a bit so you arent rubbing the fenders all day long
2010CRX
some pics of the some what finished foot work.... still got to add some sway bars and do up the brakes and rear axle swap....
Im in love with the wheel/tire combo. So many ppl are runnin tires that are too narrow or too wide, so it makes a proper setup look soo much better to me. The sidewall looks good too. Not too short.
