gsr block b16 head
  • Thread starter Thread starter turboef87
  • Replies Replies 4
  • Views Views 3K
turboef87
gsr block p30 pistons b16 head. The p30 pistons im ordering are brand new with new rings. they are standard bore with stock rings.. They should fit rite in correct ?? gsr block has stock rods and crankshaft. any valve clearance issues with this setup. ive looked at rite ups on this but havent seen them with the b16 head usually just full gsr with p30 pistons
i think it's like right on the limit lol but it should work and with a nice compression bump
I'd still do more research on it but,
good luck to you
The bores are the same, and if you are using gsr rods they will fit fine. But check your clearance with the putty test. Ive never used p30s, i only know that pr3s work no problem.
