im going to skunk 2 the shit out of the car and run low to high 12's..
Not only only do you think you'll run 12's with nothing but bolt on skunk2 parts but you're also going to waste money on parts that were meant for an all motor build then go turbo? :disgust1: I guess... it's your money...Tim going to skunk 2 the shit out of the car and run low to high 12's..then turbo =)
There is only one cam seal and only one header.skunk 2 cams....cam gears...cam seals...fuel rail...intake mani and throttle body....headers...coil-overs..retainers..springs...forged valves...all by skunk2 brand
93 honda civic vx hatch.
built lsvtec
95 b18b1 block
oem honda pr3 b16 pistons 11:5.1 comp.
oem honda piston rings
arp rod bolts
oem honda crank and rod bearings
type r oil pump
gsr water pump
gsr timing belt
oem honda headgasket.
hondata intake mani gasket
p30 b16 intake manifold
dc sports race header with 2.5 inch collector
2.5 inch exhaust with 2.5" vibrant muffler
golden eagle lsvtec kit
99 b16 head
supertech valve springs and retainers
gsr cams
gsr trans with act clutch
chipped p28 ecu
with cams and a tune car will easily go low 13's. as of right now best time is 13.9 on bf drag radials.
its captiva blue with a new front end. so the front is black. has a dent and small rust on driver side quarter panel. other than that its clean. rides smooth. stock suspension in the back with coilovers up front. real jdm headlights with jdm corners. ek yellow fog lights. cf duckbill.
gsr rear cloth seats and integra ls cloth front seats. clean black interior. 226k on the shell. clean title. comes with steelies and hub caps with brand new tires.
The kid i bought the car from ran it at the track and he ran 13.9...i have the slip...he wiegh's 300 pounds...i wiegh 150 lol...im going to skunk 2 the shit out of the car and run low to high 12's..then turbo =)...who knows what ill run lol
How did you come to the conclusion that these parts will put you anywhere near 12's? I really want to know. Not because i'm trying to talk shit but because i really wanna know how these theories come about so we don't have a ton of misinformed people out there...skunk 2 cams....cam gears...cam seals...fuel rail...intake mani and throttle body....headers...coilovers..retainers..springs...forged valves...all by skunk2 brand
Set a realistic goal and work toward achieving it within a budget.what should be my next step????
but what should i do to the car next??
the motor and tranny are almost worth 3 grand. your pretty much getting a free car =)
