If you take two completely stock heads, one a B16A and one a GSR, and set them side by side, they will both flow the same; however, the GSR will yield a slightly higher compression, thus giving you more power.
If you port and polish both heads, giving each head the same amount of work, the GSR head will still yield a higher compresson ratio, thus giving you more power.
If you put performance camshafts, stiffer valvesprings, and lighter retainers on both heads, the GSR head will still yield a higher compression ratio, thus giving you more power.
If you then take and put bigger valves in both heads, the GSR head will STILL yield a higher compression ratio, thus giving you more power.
It's not a matter of opinion, and it's not something that can be discussed one way or the other. There are two things that are absolutely, without a doubt, 100% certain:
1. Bitches be treacherous
2. GSR head > B16 head
Period.
