In an attempt to help you brainstorm.....IAT sensor needs a new plug so you need to source one out and extend the line. I apologize but I am not sure about the color codes as they will apply to the correct IAT plug for the sensor. If you have access to a local junkyard/dismantler/recycler go there and find an OBD2 DOHC VTEC to use as a reference
One of your plugs that isn't being used is for the evap purge solenoid. It is a small solenoid that has vacuum lines that lead into the charcoal canister. JDM motor do not use this solenoid.
