Exhaust Hangers
  • Thread starter Thread starter jamesA
  • Replies Replies 28
  • Views Views 9K
I installed the polyurethane hangers this afternoon on the three aft hanger locations. The two in the front (behind catylytic converter) are ok, so I'll do them another day.
Doubled up on the passenger side aft location as pictured.
They were suprisingly easy to install. The holes in them for the mounts are large and with a little white grease they slipped right on. I wore a pair of heavy work gloves and went at it armed with white grease, a utility knife to cut the old one's loose and a large screwdriver for prying.
I'll let you guys know in a couple of months how it works out - I expect good results here.
To the OP - good luck with yours. :thumbsup:
Yeah, let me know in about 7 months how they're still holding up. I installed this last set of ROL hangers in November.
As requested & promised - pictures a little over a year later - problem solved. Thanks to E_SolSi for the solution.
Glad this got resurrected. I got a set of 5 for my mirage before i took it off the road... :/
