nofxSOHCcrx
Had a post shortly ago about using a S14 block and S13 head (SR20DET), but decided to just use the crank of the S14, in the S13 and get new bearings and swap over the pistons and such. Been taking some pictures as I've been going, and we'll see if I get everything right in the end.
So far the car has::
SR20DET (Black Top)
Top mount turbo Headers
Exhaust
Frankenstein Turbo...Don't know much about it, but friend does, had him look at it, said it was better than stock...so w/e.
850cc injectors
Apexi Power FC with controller
FMIC
Koyo radiator
ARP Head studs
Mahle Clevite Thrust washers, rod bearings and main bearings
Energy suspension Sway bar bushings, and end link bushings
Apexi 1.5mm metal head gasket
Spec Clutch and flywheel
Garage Tune suspension
OEM intake gasket
OEM exhaust gasket
Rocker arm stoppers
I'll add more later when I think of it.
Took off fenders, bumper, lights, etc before I got started...
Right now, the engine is apart, just got all the bearings today
Upside down...oh well...
Had the block decked and the head shaved...
The S14 Block that the crank will come out of
Engine out, on the stand
Head
The light weight flywheel
Clutch
Cams out
Tried cleaning up the pistons, but didn't do that much, better than no cleaning.
Transmission cleaning as well...kinda half assed it though...
All my parts and bolts...bagged and tagged.
The rod with the spun bearing...
S14 crank coming out...don't laugh at my horrible rigging.
S14 crank, bearings, caps, pistons, and stuff...
Bare S14 block
My energy suspension stuff...and my Tein whatchamacallits...
Almost had 3 wheels off the ground with one jack stand...
Found out I spun the bearing because I was losing oil from my return line on the turbo while I was drifting...shitty...but so far fun to rebuild...
Still going to order::
OEM water pump
OEM Thermostat
Timing chain tensioner gasket
OEM IACV gasket
Mahle/Clevite oil filter (For break in)
6Qt Royal Purple break-in oil
6Qt Royal purple 10-30 oil
Royal Purple Oil filter
Royal Purple75-90 gear oil
Need to pull off my diff and weld it up, then I should be done!
I'll post more pics when I'm done with the bearing install tomorrow. Should be fun...
The car before the bearing
SR20DET (Black Top)
Exhaust
850cc injectors
FMIC
Koyo radiator
ARP Head studs
OEM intake gasket
OEM exhaust gasket
Rocker arm stoppers
Head
Clutch
Cams out
Bare S14 block
OEM water pump
OEM Thermostat
OEM IACV gasket
