2004 civic ex
a/c compressor not kicking on, already ruled out (low?) pressure switch by the dryer canister
believed to be electrical fault
low side reads 120ish psi which is normal for an equalized non functioning system
i know its extremely high for the low side if the system worked, but thats not the case
so any ideas on where to start looking for the electrical fault?
i tried relays and fuses but did not find one specifically for a/c and i swapped every relay that could possibly be associated with the a/c under the hood.
