I've almost owned a lot of bugs, haha. They're really cool, easy to work on, and pretty damn cheap. Just never actually pulled the trigger on one.
That's impressive and risky, haha. I bought my Integra with 60 something thousand. It has over 205k now and I've done the belt twice.
she says her husband is a car geek, humph! its lowered, low profile tires, fart can exhaust, but wont put a belt on it, she doesnt care for what he did to it, but its her only transportation, I try to tell people to replace their belt every 75,XXX miles for daily drivers, & play toys that get revved alot I tell them drop back to 50,XXX miles, as precautionary measure.
I will say I am not versed in timing belts on Hondas, but I have put literally hundreds of belts on vehicles, as well as replaced heads on those that had them snap. most belts seem to go between 115,XXX & 140,XXX miles before they break, but I have seen a few exceptions, saw a lady crying blues when her belt broke on her Accord, at 290,XXX, it was at a different shop & I wasnt guy working on it, she had bought it new, and didnt understand the consequences of not replacing. I know another idiot driving a Ford Contour with a Ztec engine that has 189,XXX & its on original belt, "they cant afford to replace" it was bought from a friend of mine that bought it new, so I know of its history.
back to the VW bugs, they are fun cars, however dont ever buy one unless you are prepared to tinker! it has 8 brake adjusters, 1 for each shoe, & as they wear your brake pedal will get closer to floor, till you need to pump 2 times or even 3 times to have brakes, chainging oil is alot more serious, it doesnt have a filter & only holds 2 & 1/2 quarts, so change at 2000 miles, screen every 3 or 4 changes, then adjust valves every other oil change, or if too noisy, or if you sense a loss of power, you could have a valve receeding & that got tight & loosing compression, the alternator / generator belt, needs to be adjusted fairly often, it is adjusted with shims between pulleys, & it it gets loose, the fan wont cool & you will over heat, also you will need to clean & adjust points as necessary, or convert to electronic ignition, if all the sudden engine stops idling, its an inexpensie solenoid on carb to replace, or run a early carb that doesnt have that feature,
and when it gets cold, you will be tinkering with carb adjustments, & choke adjustments, also dont plan for great gas mileage, most only get about 25mpg, yes you can do better, but it isnt easy, & will take several paragraphs to explain, my DD got 33 to 35mpg, VW also had factory fuel injection, but it was very problematic, I cant recomend for anyone wanting to drive farther than they can afford to get towed home, and back to brakes, there is a solution to having to adjust all the time convert to disc brakes. but its expensive, or you will have to know how to adapt. now for the bodies crawl under & look at floor boards, rust is your enemy! look closely, now look at heater channels, any holes & you wont get good heat, & too much & you loose frame strength, now look at frame head, & front suspension, if a super beetle it will have struts, if a standard it will have a beam going across, look at its mounting points. I have worked in VW bug repair shops for years back when they were alot more popular, now after you get over that, & like thinking outside the box WELCOME, lol.... its all second nature to me. I bought my first bug when I was 13, I am almost 47 now, & rebuilt the engine at 13 years old, the engine was a 1968 model, & has a few minor mods, I still have that engine, & its only been rebuilt 1 time since, & its in a 71 Super, that rust got to, the 63 bug it came in I still have, but its been parked over 20 years, I also have a 72 super, & a 73 sunbug, plus back half of a 73 standard I cut up, it was way to far gone to think of rebuilding, & I have the 1959 at shop I am building from ground up.
no intentions of performing anything like this right now, but since the comments on the V6 conversions, I looked it up on here, looks more like a running joke as people asking cant do the conversions? I am intrigued as whats the issue? fabricating? & the lack of skill to make custom mounts & hang engine & tranny correctly, what I sense would be difficult is axles correct length, or having to have axles sent out to be re-splined, & the actually wiring engine to car. to me fab work is easy, I have been welding since I was 9, and have access to alot of metal working tools. I have done 2 V8 conversions to front wheel drives, 1 was a Chevy Citation, the other was a pontiac 6000. talk about fun!
I was reading so many arguments against the v6 conversion due to weight issues, but I have seen autocross won with guys with way too much horespower and front end weight able to make up coming out of turns & through the straights, versus cars that actually handled, for example a 302 in a ford pinto, winning versus 20 other cars more suited to actually win. sometimes nothing beats cubis inches, except cubic $DOLLARS$, the pinto was all over track, but it won by sheer acceleration and speed.
