b18c4 into ee8 crx
  • Thread starter Thread starter sycrx2006
  • Replies Replies 5
  • Views Views 5K
sycrx2006
im planing on a b18c4 engine into my crx as i killed my b16.
im running obd1.
some one said to me that i can get away with swapping all my b16 sensors onto the b18c4 engine to save wiring. is this right??
if not what is the best way to go.
i can eather go b16 head on the b18 engine with b18 cams
leav ethe b18 intact and use the b18 engine lume
maybe swap sensors over and use my engine lume
if i do it that way will i need to rechip my ecu.
i've looked and looked but cant find the right info
cheers
For starters your reffering to a b18c5.
You can just put the parts off the b16 onto the c5 (alternator, distributor, injectors), and it should fire right up.
But you need to change ECU's. (use the ITR ecu)
im deffo using a b18c4 vti engine. its got the p72 head
B18C4 is the engine from 96+ European Civic 1.8 VTI - google B18C4 and you will find dozens of references to that engine
