hondaburner95
Banned
Hey Can anyone point out the laws for airbags in virginia , seems I failed state inspection for having an aftermarket steering wheel . Guy said for 1500 he could get it straight , I said shit !!!! So I have been looking and looking for the airbag laws and cant find shit in virginia , heres the requirement in va to get inspected.
REQUIRED OFFICIAL INSPECTION PROCEDURE
Each inspection consists of the following items – for further details consult the "Official Inspection Manual":
1. - REMOVE OLD INSPECTION STICKER.
2. - DRIVE VEHICLE INTO INSPECTION LANE.
3. - INSPECT BRAKES FOR:
6. - INSPECT OTHER LIGHTS FOR:
11. – INSPECT HORN FOR:
17. – INSPECT AIR POLLUTION CONTROL SYSTEM (1973 and Subsequent Models) FOR:
(a) Holes which allow exhaust gases to enter occupant compartment.
(b) Conditions which create a hazard to the occupants.
23. – ISSUE STICKER:
(a) If approved, place approval sticker on the vehicle, and give pink copy of certificate to operator.
(b) ALL DEFECTS MUST BE CORRECTED AND THE VEHICLE REINSPECTED WITHIN 15 DAYS.
THE DRIVER MAY BE IN JEOPARDY OF RECEIVING A SUMMONS FOR ANY DEFECT STILL
PRESENT ANY TIME THE VEHICLE IS OPERATED ON THE HIGHWAY.
NOTE: If you have a specific question with regard to Motor Vehicle Safety Inspection or Inspection Requirements, you can review the safety inspection manual, in part, at MOTOR VEHICLE SAFETY INSPECTION RULES AND REGULATIONS (Legislative Information System > 2007 Session).
Virginia State Police employees cannot give legal advice, nor interpret the law for members of the public. Information within this Web site is provided for general guidance purposes only and may not apply to all factual situations. Persons needing legal advice may contact Virginia Lawyer Referral Service at 1-800-552-7977 to be referred to a private attorney for a 30-minute consultation for a fee of $35.00.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l16 level1 lfo1; tab-stops: list .5in">Worn, damaged or missing parts. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l16 level1 lfo1; tab-stops: list .5in">Worn, contaminated or defective linings or drums. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l16 level1 lfo1; tab-stops: list .5in">Leaks in system, proper fluid level.
- Worn, contaminated or defective disc pads or discs.
(NOTE: A minimum of two wheels and drums must be removed from each vehicle at the time of inspection. Consult the official inspection manual for exceptions.)
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l18 level1 lfo2; tab-stops: list .5in">Broken or missing parts. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l18 level1 lfo2; tab-stops: list .5in">Proper adjustment.
- Standard factory equipment or equivalent.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l22 level1 lfo3; tab-stops: list .5in">Approved type, aim, and output. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l22 level1 lfo3; tab-stops: list .5in">Condition of lamp, wiring and switch.
- Beam indicator.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l21 level1 lfo4; tab-stops: list .5in">Approved type, proper bulbs, condition of lenses, wiring and switch. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l21 level1 lfo4; tab-stops: list .5in">Aim of fog and driving lamps.
- Illumination of all lamps, lens color, and condition of lens.
(NOTE: Every vehicle must have a rear lamp showing a red light to the rear, a white light illuminating the rear license plate; vehicles over 7 feet wide or extending 4 inches or more beyond the front fender extremes must be equipped with approved clearance lamps and reflex reflectors. Count load in measuring.)
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l7 level1 lfo5; tab-stops: list .5in">Approved type, proper bulbs, condition of lenses, wiring and switch. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l7 level1 lfo5; tab-stops: list .5in">Correct indications and tell-tale (visual or audible).
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l29 level1 lfo6; tab-stops: list .5in">Wear in bushings, kingpins, ball joints, wheel bearings, tie rod ends. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l29 level1 lfo6; tab-stops: list .5in">Looseness of gear box on frame, condition of drag link and steering arm. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l29 level1 lfo6; tab-stops: list .5in">Play in steering wheel. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l29 level1 lfo6; tab-stops: list .5in">Wheel alignment and axle alignment. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l29 level1 lfo6; tab-stops: list .5in">Broken spring leaves, and worn shackles. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l29 level1 lfo6; tab-stops: list .5in">Shock absorbers. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l29 level1 lfo6; tab-stops: list .5in">Broken frame. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l29 level1 lfo6; tab-stops: list .5in">Broken or missing engine mounts.
- Lift blocks.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l30 level1 lfo7; tab-stops: list .5in">Condition of tires including tread depth. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l30 level1 lfo7; tab-stops: list .5in">Mixing radials and bias ply tires.
- Wheels that are cracked or damaged so as to affect safe operation.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l19 level1 lfo8; tab-stops: list .5in">Rigidity of mounting. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l19 level1 lfo8; tab-stops: list .5in">Condition of reflecting surface.
- View of road to rear (Truck mirrors must extend at least halfway beyond edge of body) – (Visibility 200 feet to rear).
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l6 level1 lfo9; tab-stops: list .5in">Electrical connections, mounting and horn button.
- Emits sound audible for a minimum of 200 feet.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l26 level1 lfo10; tab-stops: list .5in">Approved type safety glass. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l26 level1 lfo10; tab-stops: list .5in">Cloudiness, distortion or other obstruction to vision. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l26 level1 lfo10; tab-stops: list .5in">Cracked, scratched or broken glass. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l26 level1 lfo10; tab-stops: list .5in">Stickers. ALL UNAUTHORIZED STICKERS MUST BE REMOVED. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l26 level1 lfo10; tab-stops: list .5in">Sunshading material attached to the windshield to ensure it does not extend more than 3 inches downward from the top of windshield, unless authorized by Medical Waiver Certificate.
- Operation of left front door glass.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l1 level1 lfo11; tab-stops: list .5in">Operating condition.
- Condition of blade.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l20 level1 lfo12; tab-stops: list .5in">Exhaust line-manifold, gaskets, pipes, mufflers, connections, etc.
- Leakage of gases at any point from motor to point discharged from system.
- Illumination of rear plate.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l13 level1 lfo14; tab-stops: list .5in">Operating condition of hood latch. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l13 level1 lfo14; tab-stops: list .5in">Presence of emissions system -Evidence that any essential parts have been removed, rendered inoperative or disconnected. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l13 level1 lfo14; tab-stops: list .5in">Fluid levels that are below the proper level
1. Brake fluid.
2. Power steering fluid. - Power steering belt - proper tension, wear, or absence.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l8 level1 lfo15; tab-stops: list .5in">Installation.
- Operation.
(NOTE: This includes the catalytic converter and the fuel tank filler pipe.)
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l12 level1 lfo16; tab-stops: list .5in">Anchorage. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l12 level1 lfo16; tab-stops: list .5in">Location.
- Condition.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l27 level1 lfo17; tab-stops: list .5in">Approved type.
- Installation.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l25 level1 lfo18; tab-stops: list .5in">Handle or opening device which will permit the opening of the door from the outside and inside of the vehicle.
- Latching system which will hold door in its proper closed position.
- <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l14 level1 lfo19; tab-stops: list .5in">Any part that is not securely fastened. <LI class=MsoNormal style="mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l14 level1 lfo19; tab-stops: list .5in">Liquid fuel leakage.
- Fuel tank filler cap for presence.
(NOTE: The validity period of the rejection sticker shall include fifteen (15) days in addition to the day of the inspection.)
