i have a question about the engine harness when putting a b16a2 into my civic vx i got a jdm b16a2 can i use the harness it came with or do i need to use the one off the original vx engine also can i use stock drive shafts and shift linkage and motor mounts
it would be the easiest since you are pulling the old motor out anyway. P30 ECU will look for knock sensor which the VX wiring harness does not have. don't listen to "EG6SiR" he is bad for you! that is more work than you need to do if you already have the ECU and matching wiring harness!
BTW you don't have a JDM B16, JDM's are B16A no numbers after the "A"
thats why i said wire the knock.. no sense in changing the wire harness if the one in the car already is wired for vtec.. its one wire you have to run and its not hard at all..
as for me being bad for him.. hahaha.. please, dont kid yourself
Isnt the vx already wired with a knock sensor since the stock engine is a vtec?
This thread be 6 months dead...and you just brought it back to life...good work...
