make my crrx work
fuel pressure 45, no less then 209 in all cylinders, injector 1 to a1 inj. 2 to a3 inj. 3 to a5 inj.4 to a7 ground all injectors to integra resistor box ran red wire from inj res box to a15, moved c1 an c2 to b10 an b12 and ran the blu/grn and blu/yllw to c1 an c2, all hoses and sensors pluged, and switched tps wires on ends with extension and eacv, i am out of idieas on this, any help would be great
yes, your injector wiring will not affect the spark, it is ignition related. Have the distributor/coil tested.
Take off the cap and grab ahold of the rotor and see if you have a lot of play in the shaft. You prob need new dizzy.
