wiring harness Q
  • Thread starter Thread starter E.N.G
  • Replies Replies 5
  • Views Views 1K
E.N.G
Hi i have a zc engine that i just put into my 5 spd 89 crx. From what model car and what year do i have to use the wiring harness from. Also will a obd 1 ecu work for this swap
Thanks
you need an si harness(in-dash,and under-hood) and a si or ZC computer
not if he has DPFI. Si has to modded to work on DX chassis, use the fucking DX harness and modify it, been done millons of times take like 1 hour.
gotdamn n00bs fucking search. Use your stock haness and convert to MPFI. Only way to use a OBD1 ECU is to get the ECU jumper harness and OBD1 Distributor FOR THE DOHC ZC. Search will answer your questions
