LS_VTEC
you get the BRAKE
So I guess I will be starting this thread which will most likely go on for about a week to two weeks depending on machine shop turnaround. This thread will be a step by step build of my mild ls-vtec setup. As I am still waiting for parts to arrive in the mail and the head from the machine shop I will start off here.
B18A1 short block
jdm b16a head (1st gen)
So far, the parts list is as follows:
8mm ARP Rod bolts
ARP Moly Lube
ACL Race Rod Bearings
Clevite Bearing Guard
Shotpeened LS rods
CTR pistons (stock bore)
Rear Main Seal
gsr oil/water pumps
ebay lsvtec conversion kit
Pictures and detailed how-to coming as soon as I have all the parts to assemble (within the next week or so) and I will start the buildup proggress.
			B18A1 short block
8mm ARP Rod bolts
ARP Moly Lube
Shotpeened LS rods
Rear Main Seal
gsr oil/water pumps
