INJEN78
HS LEGEND
ok i know this has been covered before but i cant find the correct info,,and im just basically rechecking everything i will need..
i am going to be swapping a b18a1(obd0) into my 1991 civic si(obd0)
now i know i will need the mount kit,the ecu(pr4?),the shift linkage,
what else will i need??
i know i need to either cut the front crossmember,or get the traction rod setup,,and i need to put a dent in the drivers side bay(or could i just use a 1 groove crank pulley,im not running powersteering or ac)
any info would be great
