obd1 b16a into my obd0 ls integra what do I have to do?!?
  • Thread starter Thread starter JDM_JCb16a
  • Replies Replies 6
  • Views Views 4K
JDM_JCb16a
JDM_JC
hey ok so I'm trying to put a 95 obd1 jdm b16a into my 1990 ls
integra what exactly do I have to do this is a complete swap
Its coming out of a 93 integra and it runs fine so my question is
what will I have to do to get it to run
Also I want to know what I'll have to do to get my ls b18a which Is obd0 into the 93
Integra which is obd1 any help would b greatly appreciated thanks
you might need to possibly convert it to obd1,depending on what ecu youre running, run some vtec wires, and some small stuff.. should be pretty straight forward. check out the tech/refferance section, you will find most of what you need to know!;)good luck!
Hahaha. Possibly because the cannon plugs won't begin to match up. :lmao:
Try searching for "OBDI conversion" (no quotations) and see what you get. ;)
i was actually reading two forums at once.... i tend to do that alot lol....
but for some odd reason i was reading another forum about someone that had a 90 and a 92 integra..... and the person wanted to take the motor out of the 92 which was converted to OBD1 and wanted to pull the motor out of the 90 and put into the 92 and vise..... so i read it wrong and posted wrong comment.....
damn it all to hell thats what i get for miss-reading hahahhaha
If you are putting an obd-1 engine in your DA then its good to do a obd-1 conversion and run a p28 ecu obd-1. This will require obd-0 to obd-1 jumper harness which will be $$$$$$$$$ but worth it cause you have more options to choose from.
