help help need a quick reply
  • Thread starter Thread starter mintoxik
  • Replies Replies 15
  • Views Views 2K
mintoxik
hey fellas so i have a jdm b16a block i found a b18 head from a ls integra will it work or should i not waste my time im new to the import world so thnx guys
but will it be worth my time and can i make it vtec?????
my car is in the works right now it got stolen now im on the rebuild thnx :)
vtec is for gas economy. if you want to go fast, just get cams that are just as agressive as vtec lobes...
companies like crower can custom make you cams to any specs
so i should get the ls head if i wanna go fast well i can honestly say thats a first ive ever heard can u give me a ball park of numbers that would be great but thanks for all the help fellas
What I ment is if your only worried about running at the track and making quick quarter passes, then you can get away with just large, agressive cams in a non-vtec head. Blanco is correct tho, you will lose low end power.
If your a street car, and you can find a vtec head, then it'll work a little better for your application. I'm not sure what goals your going after, or what numbers your wanting. Take a look at our reference section and you can look at what motors have what features, along with a lot of other great useful information.
then get back to us
thnx i was just trying to get a quick fix so ican get my b16 in my car but forget it ill just find a b16 head
it will work any b series anything will go with any other b series something
Not exactly true. The B20/B21 from the old Preludes isn't compatible with any of the other B-series engines.
Good call. You'll be much happier with the B16 head. The LS head doesn't flow very well in stock form, but at least it's usually paired with a 1.8 block, so it makes decent torque. Paired with a smaller B16 block though, you'd be getting the worst part of both motors.
"VTEC is the #1 choice for Honda enthusiasts!" This is what I heard some old fart bag say at HIN six years ago. Everyone laughed it off like it was nothing... now look how far it has gone today... :)
I wonder how long the LSVTEC concept has been around. I'm sure no one ever imagined that either.
ill let you guys no how it goes i have a long way to go cuz my car was stolen now i have some reason to take it all apart and go from ground up if u guys have ne idieas it would help alot thnx again guys
My friend, I really do wish you the best on everything, as I have been there. My car was stolen once in 2000 and broken into three times in the past two years. Best of luck.
