maybe he is a fucktard. Lol
Yes, I believe so. Like Blanco said, don't take anything you hear from friends as truth, look it up and research it first...
Stock gsr
The build is an ls/vtec. It is only on the short block, which is for sale.
Probably because a built B20/VTEC will make significantly more torque.
If there was a "best" don't you think we'd all be running the exact same setup?
CP pistons expand less, so I'd chose them.
Does b20 block have an 91mm bore? Wondering.. Cause my friend told me the b20 block have 91mm bore..
But I already know all b series engines have an 81mm bore.
Girdle's don't really help all that much. Also, he will be boring out 3mm, not 1.5mm being the gsr has a stock bore of 81mm.
A few posts above this I said the vaguely told you a b20 is 84mm.
You really need to stop listening to anything your "friends" tell you. In all honesty, it's you who doesn't know what you're talking about and I'm not knocking you.... It seems like you are trying to learn by asking questions but you refuse to really listen to our answers, we answer and then we tell you to research and you just ignore it.
We aren't telling you to search because we don't want to help you, we are telling you to search because you need to learn and read up on what you want to know. Everything you've asked has been covered multiple times.
It's ok if you don't know everything, I sure as hell don't know everything. But I also don't try and use my friends as an excuse for things I say wrong or that I'm misinformed about.
Yes total of 3mm in diameter but taking off 1.5mm from the cylinder wall thickness.
Why don't you buy it??
LS_Vtec's already built bottom end and all you have to do is swap heads and put her in. I know it isn't a B20 but it is already built.
yeh i am wait for him to give me the price.
p.s i already have the stock gsr in my 95 honda civic ex coupe
that's your car?
do you think the b20 block with gsr head/tranny is the best of the motor ? Cause I have the b18c1 engine into my 95 honda civic ex, one of mine friend told me to get the b20 block, do u think should I get the block?
help!
just give me a little advice thanks!
