thats what i said. so i dont know what the hell is going on but im getting really sick of it. once the mounts come in, if that dont solve it, ill throw the avid axles on it, if that doesnt do it, ill have the tranny looked at, other then that.. i dont know what to doHmmm. It's just weird that 100% brand new axles are warped yknow...
its not the flywheel i already changed that out.. as posted above.
as far as wheel bearings go, its not that. ive checked those and it DID NOT do that before i had the swap done. im just gonna throw axles and mounts on it and see if that does it. im thinking about taking my lowering springs off to to help change axle position.
running at stock high with CRX SI 14's is gonna SUCK, but maybe it will help.
WTB POLISHED GSR BLADES/TWISTIES!!!![]()
If you want your car to be light, get some Hx's. Blades are heavy. From previous posts, it seems like you want a nice and light car.
I bought some polished GSR blades for 250![]()
Sweet. Post pictures.
Let me know how those hasport mounts work out for you. I traded my 92 civic Si for a 97 dx hatchback...I've already ripped the stock D16Y7 motor/tranny out and am just ordered a JDM GSR from Hmotorsonline...it should be here tomorrow...I have everything lined up for the swap....I've swapped a B16A into a 96 DX coupe before but it was just a transplant from a wrecked 98 so it was easy...You have any advice for install of the swap since you have the exact same setup? I'm also in the Seattle area.....I will have pictures posted shortly of the swap once it comes in...
Maybe your girlfriend left her vibrator under your seat, and it is intermittently coming on? Possible? Yes. Probable? No...
ya... just found out how bad the hasport ones are, have you ever tried inserts?If you are using oem mounts, or inserts than it shouldnt vibrate. Solid mounts, like the Hasport ones vibrate a lot. A fucked up flywheel will cause vibrations, an unbalanced crankshaft, damaged crank pulley and/or assembly will cause it as well. Poor installation may also play a part in your problems. I doubt its your axles, unless they are severely bent but even then, you would notice is in any gear at just about any speed.
sorry about that, i read it wrong and was in a bad mood before i had read it.
ignore the -rep man. my bad. ill pass you back some +rep when it will let me.
i shoulda said something first i just thought you were trying to be a dick all of a sudden. sorry again
