1st gen b16a into 92 si questions please help!!
  • Thread starter Thread starter calhoun
  • Views Views 798
calhoun
ok i know this is not a swap you are supposed to do but i have the engine in my crx and want a nicer car. so i want to put it in a 92 si shell i found. can it be done? i seached so please dont tell me to i know i am new but i could not find much info on this swap. i know my car has a cable tranny and the hatch had a hydro. if possible what else am i ging to need other then my running engine?
also i blieve the car curently has a integra tranny in it because there is a shaft coming out of it before the axle on the driver side and i have never seen this on any other b16a's. any help would be appreciated
thanks, chris
well you can use your b16a in your 92 all you need to do is one of two things
1 get a cable to hydro tranny convertion kit from hasport or
2 sell your tranny and get a hydro tranny
also i am not sure but i think your shift linkage will not work on your car from the 91 but you can try if not check your local junk yard for a 92 and up b16 civic (not del sol) or a 94 and up integra
