93 dx hatch help
  • Thread starter Thread starter mad_hatter
  • Views Views 928
mad_hatter
Its Da Mad Hatter
ok its a 93 hatch with ek front end, i just got it and i cant get it to start, the car turns over and i checked for fuel its def. getting fuel, theres no spark, i checked continuity on all plug wires, then ran tests on the ignition coil and all that, everything should work, i put a friends dizzy on there, still nothing, ive had this problem before but it was ignition coil but what i cant figure out is what is the next step,
check for fuel - works
check for spark - nadda
check dizzy - works
what is next down the line, all my fuses are good and everything, if timing was off it would still at least shoot some spark correct, im stumped, o yeah the motor is plain jane d15 all stock 113,000 miles
nevermind i found it, dude i got it from tried to get up on me or he screwed something up and couldnt figure it out, it was the damn acg fuse, i noticed it just wasnt there pop it in crank on it, ill be damned fired right up, hell yeah
