Yes, the ECU will have to be swapped, along with a complete head (distributor, cam, cam gear, timing belt...) and (I think) a VTEC water pump.
Are you sure you want to do this swap? It's only going to net you aout 10 horsepower at the flywheel.....You may be better off saving for a turbo or an engine swap.
