95 Hatch with B18ls RPM?
  • Thread starter Thread starter 95hatchcx
  • Replies Replies 5
  • Views Views 967
95hatchcx
When i'm running about 65mph i'm running like 3300 rpms? Is this
normal for an B18b Ls motor it has the integra tranny also.
Is my timing messed up or my gearing?
what size tires are you running???
you should be at ~73 mph at that RPM in 5th gear
Hmm did you put the motor in to the car youself or did you buy it this way? Because it sounds to me like you have a Gsr tranny. My old car was a 93 hatch with an Ls motor and I had a Gsr tranny and that was about the RPMs I would be at around 65 (maybe a little higher).
well if you want to know for sure get yourself an after market Tach and hook it up to your distrib and go from there because my car in the winter the tach stops moving so i put on a tach and of course now my tach in my car works in the winter but i would use a tach i found them cheap for like 40 bucks on ebay go that route.
