Adding pins to connectors
  • Thread starter Thread starter brianteel
  • Views Views 743
brianteel
I am doing a 92 civic motor swap and have to add the wires for the vtec. What would be the best way for me to do this
To make it look very professional you can run the wires into each connecter plug in a spare spot, otherwise just run the wires all the way from the vtec selinod and where ever else along the wiring harness straight through to the ecu. then plug them in, in the correct spot.
Darin
92 Civics were already wired for vtec, I beleive. Anyways, just add the vtec pressure switch and solenoid, run them through the firewall by the battery and put them in the ECU
if you have a 92 car you won't have to run vtec wires through the firewall to the ecu because they are allready there. all you will need to do is run a wire from the solonoid and pressure sensor to the correct location on the engine wiring harness.
I did this on my 92, pm me if you have specific questions
good luck
