axle help
josh_crewdson@y
will 92-00 civic d series axles fit in a 90 civic?
I think they'd be too long, but I'm sure someone's dealt with this before.
couldn't find any info...
they slide into the 90 dx tranny and hubs.. i put them beside each other and they're the same length.. impossible? i thought the ef's weren't as wide as the ek's, body wise?
call a parts place and get the part numbers for each year.
if they match, then they're the same.
if they dont match, then they arent the same.
sometimes, you cant see the difference in length by eye. 1/8th of an inch can be the deciding factor of whether or not they fit. and you wouldnt be able to tell that little bit of difference by eye.
what axles would you use in a 90 civic dx hatch with a d16z6 swap?? i've searched the site quite a bit and can't seem to find the answer.
i need help wit my axel problem if some one could call or text me with help at 760 995 5983
make a new thread,
include the details of your question.
go from there. or, use the search function to see if your question has already been answered before.
