Ok I swaped a b16a into my crx It came with everything but the axle they gave me does not fit on the right side some one told me to try 88 integra one should I?
the axles you use depend on the half shaft you have. if you have an obd0 halfshaft you need to use obd0 integra axles. if you have an obd1 halfshaft, you need obd1 axles...... oh and an auto half shaft is a little bit longer than a manny one.
well I got the left side in fine and I guess its obd0 because it all came togather but when I put the right side in it was way off and it was really hard to pull out after putting in
