b16 head obd issues
  • Thread starter Thread starter 600ryda
  • Views Views 952
600ryda
im looking into buying a head for my b16. i got and obd2 block goin into an obd2 car, but the head that i found is obd0 will that be an issue? as far as i can tell from researching there shouldnt be a problem? are any sensors different or anything ill need to change?
If its just the head (and not the intake manifold) you just put your stuff on it and you're good to go. The cams and internals of the head are the same. You need to use OBD2 distributor and you should use a OBD2 B16A2 intake manifold (and other OBD2 stuff...obviously)
awesome thanks dude! yeah i figured that i just wanted to make sure. its been a while and i wanted to make sure there werent any sensors on the head that i wasnt thinking about.
