b16 turbo help
  • Thread starter Thread starter civic32958
  • Replies Replies 6
civic32958
i have a b16 w/ 9:1 pistons, and eagle rods. Wanna run 330 injectors, fuel pump, fmu , but i wanna do about 12-14 psi. i dont wanna run a stand alone. is that ok should i have bigger injectors?? etc..what would be good for that setup thanks
If you don't use a standalone I guess you will have to use an FMU and check valves so your map sensor will never see any positive pressure.
As for the injectors, I'm not sure but I think the 330's will be ok with the fmu.
i dont know what turbo you're using, but 330 injectors seem kinda small.
You should definetly look into uberdata, or at bare minimun the AFC hack. I mean the FMU will work but it's defenitly not efficient.
as i said, its not happeneing.
14 psi + a 12:1 fmu = 213 psi of rail pressure.
~45 is stock on most honda cars
you're asking for problems.
you need management
you need management
[post=447811]Quoted post[/post]​
your so smart :D
[post=447339]Quoted post[/post]​
Running an fmu would be a total waste if he already has new internals . . .
