anybody use this setup before? will it work? I have and am trying this setup and it seems like the trans shaft isnt as long as it should be so the throwout bearing isnt making contact. any help apreciated.
I installed the trans and it still feels like clucth isnt engaging. I can lift the clutch arm all the way with my hand. So i believe i have a problem somwhere. Salvador what clutch , press plate and flywheel are you using?
the stock gsr one, clutch dosent matter, adjust your clutch cable. if it still dosent grab then your cable is over stretch and you need to get another one from junk yard. but try to adjust first.
