heres what goes on, the p72 ecu, engages vtec 2 4400 rpm, then the secondaries at 5700 rpm
the reasn you wont hear vtec is because the transition in the powerband is so smooth, where as at 5700 its totally differnt.
as sleeper_crx said:
if your going all motor you want rpm, theres no torque in a all motor setup.
first off who are you to say i cant drive?
second, i have a dresser full of timeslips to show i know how to drive so shut up
i dont know if you know this but, the b16 piston has a dome shape to it, and the gsr is a flat top design, so makes a smaller combustion area, higher compression.
yea the b16 head flows better, but not by much. also how many stock b16s out there are running 13's?
heres my setup, and you be the judge lets see who can drive
b16a
GSR head
short ram intake
kamakazee header
2.5" exhaust
skunk2 cam gears
CTR intake cam
very basic setup, its all driver
