b16a2 into a 1990 crx vtec
  • Thread starter Thread starter wriggley
wriggley
will a b16a2 lump go in to a 1990 crx vtec with a b16a1 in it if so what work is needed will it go straight in ? thanks for any help
nope, you'll have wiring issues. a b16a2 is obd2b, therefore, your going to need to add some wiring. do you have the ecu it comes with as well? or you can convert the a2 to OBD1 with a1 parts, if they're not damaged or can be used...
but other than wiring it should be fine, unless you choose to go obd2, then you'll need the emissions equipment
why you doin this?
why you doin this?
ahh i totally forgot about that..rep for reminding
