Well.. Looks like I'm gunna pull pistons and replace rings. Blowing smoke pretty good and compression is low for my setup. Avg 210 psi, should be 270+. Afr kept bouncing around too, need a new fuel pump maybe? Only 171whp 119tq. oh and found I need to replace an axle. Yay...
I do not know yet. I haven't torn it apart yet. I've already ordered new rings and new HG. Hopefully I can tear into it tonight.Do you know for a fact you installed the piston rings wrong? Did you tear it down yet?
Ya, need to run it for a bit then next week hit the dyno again.glad you got it all back together. it would be real interesting re-do the compression test, and put in the dyno again... see what kind of difference there is.
What is the best way to do this exactly?Be sure to break them rings in
