b18a1 wiring problems
  • Thread starter Thread starter camaro boy
  • Replies Replies 1
  • Views Views 892
camaro boy
the plugs at the distribtor do not match, can i swap a d15 distribtor on a b18
Quoted post[/post]]
is your car a DX? did you do the DPFI to MPFI wiring changes? you cannot use a D15 distributor on the B18 - it does not have a CYL sensor in it that controls timing of fuel injectors - the DX has a square 5-wire connector at the distributor - you need to swap a round 7-wire connector from Si engine harness onto the DX harness - just match wire colors at both sides of the connector - if you did DPFI to MPFI wiring changes, you should have added the 2 additional wires from the ECU
