I have a Blown B18B and am buying new sleeve, should I go ahead and up to 84mm? any problems ascociated with this. i am going to be running a turbo on it and i want to get low CR pistons. what else to i need to do?
The compression ratio is up to you, what kind of turbo you want to use, what kind of fuel, poewr curve, ultimate power goals etc... most people like to stay in the low 9s for compression under boost on a Honda.
Yes, you should get aftermarket rods if you're already going to spend the money on aftermarket pistons and sleeves, along with boost. It just makes sense. I actually have a set of Eagle rods that I'll let go for $250 if you're interested.
