Check your coolant levels. If your leaking and there is air in the system the idle will bounce. Happened to me with the teg. Replaced the leaking radiator and filled the coolant. Haven't seen the problem since.
Quoted post[/post]]
Have you done that compression check yet?
Your autozone sucks.Quoted post[/post]]
Alright, I'm breaking down and going to rent a tester, I'll post later on.
Edit: I was $5 short on cash at the autozone for the deposit and was sent packing, sigh. I'll pick it up first thing tomorrow I'm in for the night.
No, that's the one im talking about.Quoted post[/post]]
By throttle screw do you mean the idle set screw or another one?
They put a different size plug in there or it's cross threaded at an angle so your socket won't go around it.Quoted post[/post]]
Ok, the idle screw was actually screwed all the way in, until it was tight, however loosening it really didn't do much except.
On another note after checking the spark plugs I found oil pooling in 3 of the 4 spark plug holes, and I cannot get the #1 spark plug out, I dont know if its maimed down in there or what but my socket wont grab onto it. Thoughts![]()
Quoted post[/post]]
I recently changed plugs on a 91 accord, and they were also covered in oil... and i mean COVERED... first thought was seals, but then the threads were covered with oil and small metal pieces... hmm rings FTW?
You took it out???Black Widow g2 said:that darn IACV... i just took mine out... no need for it at all in my car...
they get dirty and clogged so often...![]()
