brake pad install writeup w pics??
  • Thread starter Thread starter Smrcrx
  • Views Views 860
Smrcrx
I searched, but i couldn't find a thread that had pictures on how to change brake pads, and went through in detail on how to remove and install the new brake pads.. =(
Thanks
well all you do is un bolt the brake caliper to relese the pads use a c clap to push the caliper back then put the new pads on bolt her down and your done
Theres two bolts behind the disc's holding the caliper on, take them off.
Take the caliper off the discs and pull the pads out.
Compress the caliper back into place put the new pads in.
And install is reverse.
But like Blanco stated get a manual!!!
