can i blow my engine
  • Thread starter Thread starter crxpower24
  • Replies Replies 31
  • Views Views 6K
crxpower24
hi i just got a new crx with a b18a1 can i blow the engine with a ford probe turbo or how many pounds of boost can it hold or do i change pistons???:hmm:
Of course you can blow it. Careful though, that model is known to cum a lot. Just be ready for when it finishes. Hope you're a swallower.
i do i have c5 and 18a1 but its in a crx and the c5 is in my integra but the crx is lighter and faster then my integra
Going just by the title my answer would be They're your lips you can put them on what ever you would like.
well i want to know if i could put 15psi to my b18a1 with out no mobs like pistons or would the engine blow out with that many pounds
15psi is about the max as long as it is tuned right and you got the right fuel delivery going to it.. And a big intercooler..
Do you know what turbo you plan to use? 15 psi on a tiny turbo is different then 15 psi on a giant turbo...
the turbo is pretty small it looks like this but cleaner and its out but do i need to change the ecu too
its hardly even worth putting on the car if youre looking for performance
yes you will need to change the ecu, or have it chipped if it is an obd1 ecu
you will need a proper tune in order for the car to run correctly and last a while
but in all honesty, i dont think id waste my time with that turbo
