car runs but in limp mode h22 swap
  • Thread starter Thread starter actionisgo
  • Replies Replies 4
  • Views Views 4K
actionisgo
hello just got engine in 93 del sol and wired runs but doesnt rev up, im using p28 auto computer from 93 delsol,and now have a h22 5spd, wont rev up. what should i look for? computer no good? any help would be great,thanks.
it will give you a problem, but not like the one you are experiencing...
you can modify an auto ecu to become a manual. https://hondaswap.com/~pills has a write up on it
if you're topping out at 3500 rpms, you have a "Critical error"
pull your codes
re-check your wiring
i pulled the codes, i got a 4, crank position sensor, 1 long then 9 quick so a 19, auto tranny lock up control valve, 1 long , so 10, i have a 98 h22 anyone have a diagram of crank sensor,to see if it wired correct or could tell me how, the auto tranny code, will that cause this? the ten code, intake sensor could i have the 2 mixed up? any help would be super.sam
i finally figured it all out!! the crank sensor when the wires were taped they touched each other! now it runs a1, i was wondering should i get a chipped computer now, do they make a big difference?
