Cluster Problems
  • Thread starter Thread starter 2cool4vtec
  • Views Views 753
2cool4vtec
for some reason my guages never light up when i turn my car lights on and as of recently my short circuits have been getting worse.. i have a 92 civic si.. for example i notcied when i tap on the brakes my corner lights go on.. and my dome light stopped working.. then eventually these problems go away but alwasy come back.. i checked my fuses and found nothing.. im not to good w/ electrical stuff.. so wat shoud i do in reference to this problem? how can i check 2 see wat wires are cuasing the problem and where to start to look?
wiring can get pretty complicated so i would just take it to a shop, and it can get pretty exspensive so i'd try and have one of the guys do it as a side job. where are you located at???
Same thing started happening to my 89 civic hatch and all it was was bad grounds. Check your tranny and head ground and make sure there is no corrosion and they are on tight. Also on mine there is a ecu ground attached tothe wiring harness over the tranny that bolts onto the clutch cable bracket. Hope thats all it is.
