If you have access to a decent Honda recycler then (if it was me) have them show the two pedal assemblies to you
or just find a cheap hydro set up and see if she is a direct fit for mounting. (I think you might get lucky) Mounting the
Clutch Master Cylinder difficulty level will only be found once the pedals are mounted and you can see if you have a
flat vertical surface to drill the three holes through the firewall. This whole excersion and change over is rare....(or seems so to me)
so you might be venturing into new territory.
