well... im hitting that frustration point.
Car was running fine before the skunk 2 intake.
Put on the intake and car starts to throw codes.
I have fixed a few codes but here is what I have now.
Code 20 (electronic Load Detector)
Vtec doesn't work but I assume this is because the car is throwing codes. My Idle is also all over the map. It ranges from around 1000 to about 2000.
I have checked for leaks 10 times now and can find nothing.
any suggestions on tracking down a code 20. (hint it throws this code before the car is started... so If I clear the codes.. turn the ignition to on... then the code starts.
