Originally posted by VTECPOWER@Jun 19 2005, 11:10 AM Could it be code 10 and also code 14 ? The led light blinks twice so 10, which would be 20 each then 4 quick times after that.
probably 10 & 14 - do you have connectors at the right location? code 10 = IAT sensor - 2 wire connector with red/yellow and green/white wires - code 14 = EACV - 2 wire connector with blue/yellow and black wires - you should have one connector on the DX that doesn't connect to anything - 2 wire with black/yellow and orange wires
i believe that they are in the right location green plug on the 1st intake runner and the clearish one near the tb. ill check when i get home and also ill talk to peter @ rywire.
