CRX Starter Question
  • Thread starter Thread starter La_Pieuvre
  • Views Views 907
La_Pieuvre
My buddy has a 91 CRX SI. His starter went bad and he wanted to know if a 1.5L
CRX Starter is the same as his 1.6...
He has a 5-spd transmission, does the Automatic transmission starter differ?
Thanks guys :)
good question...
I checked OreillyAuto.com and this is what I found
THEY DO, you can use a 1.5 on a 1.6 as long as its a 5 Speed... SAME YEAR.
They all use the same transmissions, so yes you should be able to swap starters. The 88 is different from the 89-91 transmission though.
