D15B ECU vs B16A ECU fuel mapping ?
  • Thread starter Thread starter natecspecr
  • Replies Replies 1
Hi sir ,
I am using Honda Civic 92-95 4drs B16A DOHC Vtec Manual trans.
Just want to confirm whether the ECU of D15B SOHC Vtec can be use
in my B16A engine ? I had try to plug in the D15B ECU into my car and
start the engine , no CEL , engine running fine ,
Vtec engage at 5000rpm and rev cut at 7500rpm.
Need your help to confirm for me if i am using this D15B ECU into my B16A engine
will it be harmful ? Thank you ...........
i would run a B16A ECU.
you might be running a bit lean, since the B series requires slightly more fuel.
