does anyone know how to fix error code 8
  • Thread starter Thread starter entone
  • Replies Replies 1
entone
does any know how to fix error code 8 (TDC senser), it comes on when im driving ,i turn the car off and turn it back on, and its gone, but it comes back after i drive again, i check all the plugs and everything seems fine. dose anyone know how to fix this. by the way its a eg with jdm b18c swap.
check the wires from the dizzy to the ecu to make sure there not bad and are working properly. the colors are white/blue and org/blue check that and let me know. on the ecu they should be c3 and c13 for ground. ground is the white/blue and power is the org/blu. check for voltage. if all is good you have a bad sensor and the whole dizzy should be changed. just chaging the sensor alones gonna cost you more then what you wanna fork out for somthing else in the dizzy to go bad and have to do the same thing over and over agian. let me know if this helps.
ya boy steveo
