dual carbs or fuel injection
  • Thread starter Thread starter quadboy2002
  • Views Views 960
quadboy2002
fed-town racer
i just bought my motor for my hatch i ended up going with the d15b i came with dual carbs and i wanna know what will give me more power the dual carbs or my dpfi any help is greatly appreciated
you would need to make a lot of changes to run the carbs - the fuel injected engines use a pressurized fuel system and the carbed doesn't - you would need to make some changes in the fuel system - you would need the ECU for the carbed engine along with, i would guess, some wiring changes - the dual carb JDM D15B engine is basically the same as the USDM D15B2 DPFI engine, just has carbs - it is 98hp
FUEL INJECTION = SI (SPORT INJECTION) This is the better alternative to obtain power. Carbs were the v8s today we live in fuel injections. Carb is okay but to o much maintainence. Good Luck!;)
