Ummmmmmmmmm.............................DUH!!!If I find a head with a valve job done should I get that over one that hasn't?
how hard would it be, or should I have a shop do it?
Does the car manual have that in it or will I have to buy a new one?You just have to make sure you have a manual for the engine right in front of you
If you have a high milage engine and would feel better rebuilding it, do so. I did. However, I did a mostly stock rebuild.
I used this link (Gallery) for the engine and a Haynes and Chiltons repair manual for the chassis. Haynes and Chiltons both suck, but they're published by the same company and do augment each other's information.
Well if your doing the mini-me, It will be great to put on your a6 block. The a6 block is said to be the best d-series block. Youll just have to play around with your dizzy a little.I just glanced at the site, the engine set up was similar. I was just going to use the head from a '92.
