91 hatch with a b16 swap, keep throwing cel code 20- eld (electrical load detector) and this is what ive done as far as troubleshooting and im lost,
pulled 3 pin eld harness from fuse box in engine bay
, checked for voltage between black and yellow and ground, which goes to main fuse box under dash, good i think between 4-5 volts, and green and red and ground, which goes to ecm, or pcm, NO volts, checked the wire and nothing wrong with it and the pin connections good, so i replaced entire fuse box and nothing,
im lost here and dont know what to do or try...
, checked for voltage between black and yellow and ground, which goes to main fuse box under dash, good i think between 4-5 volts, and green and red and ground, which goes to ecm, or pcm, NO volts, checked the wire and nothing wrong with it and the pin connections good, so i replaced entire fuse box and nothing, im lost here and dont know what to do or try...
